주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5567 Back Cover Replacement
필요한 것
  1. Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/3 Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/3 Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Back Cover Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-5567 Back Cover Replacement: 2 단계, 이미지 2/2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Back Cover Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-5567 Back Cover Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-5567 Back Cover Replacement: 3 단계, 이미지 3/3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sattam Bakolka
회원 가입일: 01/14/20
732 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 34
전체 시간: 2,476
