주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5567 Battery Replacement
필요한 것
  1. Dell Inspiron 15-5567 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
  2. Dell Inspiron 15-5567 Battery Replacement: 2 단계, 이미지 1/3 Dell Inspiron 15-5567 Battery Replacement: 2 단계, 이미지 2/3 Dell Inspiron 15-5567 Battery Replacement: 2 단계, 이미지 3/3
    • Slide the DVD drive out of the laptop.
    • Remove the three screws underneath using a micro screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Battery Replacement: 3 단계, 이미지 1/2 Dell Inspiron 15-5567 Battery Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the two screws attached to the metal bracket holding down the battery.
    • Remove the screw attached to the laptop battery using a Phillips #0 screwdriver.
  4. Dell Inspiron 15-5567 Battery Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-5567 Battery Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery connecting cable from the laptop by sliding it out.
    • Confirm the new battery is correct for this laptop model by looking at the battery type and power.
  5. Dell Inspiron 15-5567 Battery Replacement: 5 단계, 이미지 1/2 Dell Inspiron 15-5567 Battery Replacement: 5 단계, 이미지 2/2
    • Attach the cable for the new battery to the laptop by sliding the cable into the port.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Saaed Chaudhry
회원 가입일: 07/15/20
382 평판
안내서 2개 작성하였습니다
York University, Team S1-G8, Melo-Thaiss Summer 2021 York University, Team S1-G8, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S1G8
1 회원
안내서 2개 작성하였습니다
댓글 한 개
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
Kat Vinson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 63
전체 시간: 7,616
