주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5567 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 15-5567 Display Assembly Replacement, Remove the Display Cable: 1 단계, 이미지 1/1
  2. Dell Inspiron 15-5567 Display Assembly Replacement, Note the Display Cable Routing: 2 단계, 이미지 1/1
    • Note the display cable routing and remove the cable from its routing guides.
  3. Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Latch: 3 단계, 이미지 1/2 Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Latch: 3 단계, 이미지 2/2
    • Lift the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 15-5567 Display Assembly Replacement, Remove the Screws: 4 단계, 이미지 1/1
    • Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
  5. Dell Inspiron 15-5567 Display Assembly Replacement, Open the Display Hinges: 5 단계, 이미지 1/1
    • Open the display hinges.
  6. Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Palm Rest: 6 단계, 이미지 1/1
    • Lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 15-5567 Display Assembly Replacement, Placing the Display Assembly: 7 단계, 이미지 1/1
    • Place the palm rest and keyboard assembly on the NEW display assembly.
  8. Dell Inspiron 15-5567 Display Assembly Replacement, Press the Display Hinges: 8 단계, 이미지 1/1
    • Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
  9. Dell Inspiron 15-5567 Display Assembly Replacement, Replace the Screws: 9 단계, 이미지 1/1
    • Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
  10. Dell Inspiron 15-5567 Display Assembly Replacement, Routing the Display Cable: 10 단계, 이미지 1/1
    • Route the display cable through the routing guides on the palm rest and keyboard.
  11. Dell Inspiron 15-5567 Display Assembly Replacement, Sliding the Display Cable: 11 단계, 이미지 1/1
    • Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the battery cable to the connector on the system board.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,121 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 한 개
Nice, is the part available?
gideon onwuka - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 2,051
