소개
In this guide, we will be showing you how to remove and replace the Display Assembly.
필요한 것
Note the display cable routing and remove the cable from its routing guides.
Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
Place the palm rest and keyboard assembly on the NEW display assembly.
Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
Route the display cable through the routing guides on the palm rest and keyboard.
Slide the display cable to the connector on the system board and close the latch to secure the cable.
다른 한 분이 해당 안내서를 완성하였습니다.
Step one incorrectly identifies the display cable as the battery cable. I think I blew the mobo reattaching the display cable. A small pop and some ozone scent leads me to believe that.
Quietech - 답글
Make your 1st step removing the back cover. Dell Inspiron 15-5567 Back Cover Replacement
Quietech - 답글
