주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5567 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove thirteen 8.5 mm screws from the bottom of the laptop.
    • Using the same screwdriver, remove the two 3.2 mm screws and slide the DVD drive out of the laptop.
  2. Dell Inspiron 15-5567 Hard Drive Replacement: 2 단계, 이미지 1/3 Dell Inspiron 15-5567 Hard Drive Replacement: 2 단계, 이미지 2/3 Dell Inspiron 15-5567 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove the three 2.3 mm screws underneath the CD drive using the Phillips #0 screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Hard Drive Replacement: 3 단계, 이미지 1/2 Dell Inspiron 15-5567 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Disconnect cable covering the hard drive by prying up on the clamp holding the cable.
    • Disconnect the cable from the motherboard.
  4. Dell Inspiron 15-5567 Hard Drive Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-5567 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the three 5.6 mm screws from the hard drive.
    • Remove the old hard drive from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Saaed Chaudhry
회원 가입일: 07/15/20
382 평판
안내서 2개 작성하였습니다
York University, Team S1-G8, Melo-Thaiss Summer 2021 York University, Team S1-G8, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S1G8
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 57
전체 시간: 2,272
