소개
Laptops can start to lose value to you when you run out of storage. This guide is an easy way to replace the hard drive for a Dell Inspiron 15-5567 laptop. When working with laptops it is important to make sure that there is no current running through the laptop and that is completely shut down before being opened up. The interior of a laptop is very delicate and therefore must be handled with great care to make sure nothing gets scratched inside that might impact the function of the laptop.
필요한 것
Use a Phillips #0 screwdriver to remove thirteen 8.5 mm screws from the bottom of the laptop.
Using the same screwdriver, remove the two 3.2 mm screws and slide the DVD drive out of the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
