소개
The input/output board is responsible for reading or writing on any storage devices that you plug in the computer. It also reads information from other components of the computer. Generally, it will need replacement if the computer is unable to read, or write on a flash drive that you plug in; To replace it in the Dell Inspiron 15-5567, you’ll need a Phillips #0 screwdriver.
필요한 것
Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
Remove two M2x4mm screws using the same screwdriver.
Open the latch for the cable using the blue opening tool by placing it under the latch (like in the second picture) and lifting it upward.
Disconnect the cable by pulling the blue tab.
다른 한 분이 해당 안내서를 완성하였습니다.
