주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5567 Speakers Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Dell Inspiron 15-5567 Speakers Replacement, Back Cover: 1 단계, 이미지 1/3 Dell Inspiron 15-5567 Speakers Replacement, Back Cover: 1 단계, 이미지 2/3 Dell Inspiron 15-5567 Speakers Replacement, Back Cover: 1 단계, 이미지 3/3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Speakers Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-5567 Speakers Replacement: 2 단계, 이미지 2/2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Speakers Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-5567 Speakers Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-5567 Speakers Replacement: 3 단계, 이미지 3/3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 Speakers Replacement, Remove the Screws: 4 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the battery bracket to the system board and palm rest and keyboard assembly.
  5. Dell Inspiron 15-5567 Speakers Replacement, Removing the Battery Bracket: 5 단계, 이미지 1/1
    • Lift and remove the battery bracket.
  6. Dell Inspiron 15-5567 Speakers Replacement, Remove the Screw: 6 단계, 이미지 1/1
    • Remove the screw that secures the battery to the palm rest and keyboard assembly.
    • Note the location of the screw that secures the battery to the palm rest and keyboard assembly.
  7. Dell Inspiron 15-5567 Speakers Replacement, Lifting the Battery: 7 단계, 이미지 1/1
    • Lift the battery off the palm rest and keyboard assembly.
  8. Dell Inspiron 15-5567 Speakers Replacement, Speakers: 8 단계, 이미지 1/3 Dell Inspiron 15-5567 Speakers Replacement, Speakers: 8 단계, 이미지 2/3 Dell Inspiron 15-5567 Speakers Replacement, Speakers: 8 단계, 이미지 3/3
    • Remove the cable by using the blue plastic opening tool.
    • Lift the first speaker gently and remove it.
  9. Dell Inspiron 15-5567 Speakers Replacement: 9 단계, 이미지 1/1
    • Lift the other speaker gently and remove it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sattam Bakolka
회원 가입일: 01/14/20
732 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 31
전체 시간: 967
