주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7537 Battery Replacement
필요한 것
  1. Dell Inspiron 15-7537 Battery Replacement, Bottom Case: 1 단계, 이미지 1/1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Battery Replacement: 3 단계, 이미지 1/1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Battery Replacement: 5 단계, 이미지 1/1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Abby Schmiedt
회원 가입일: 01/22/15
229 평판
안내서 1개 작성함
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 회원
CPSU-MANESS-W15S18G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 30
전체 시간: 6,971
