소개
The battery is needed to power the laptop. A bad battery must be replaced, which can be done with this guide.
필요한 것
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
