소개
Use this guide to replace the keyboard if you have determined your keyboard issues may be resolved by replacing the keyboard.
필요한 것
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Use a spudger to remove the base cover from the rest of bottom cover.
As it is not clearly visible in the picture: You should start to open the base cover at the screen side, to avoid breaking the plastic guides of the base cover. A flat dough scraper is a pretty good tool for that.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
Using the pull tab on the battery, lift the battery out of the computer.
These instructions look as if you ground the board first and then remove the battery.
I think it should be the other way round. First, remove the battery. Secondly, ground the board.
Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
Take the keyboard off the palm rest assembly.
I had problems open and close the clips for the Keyboard-cables. ^^ Any tips how to open and close? Thanks in advance.
다른 10명이 해당 안내서를 완성하였습니다.
3 Comments
Thanks It’s Useful
ahmed omar - 답글
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
