소개
Use this guide to replace the RAM if you would like to upgrade the RAM, or replace it if there is damage.
필요한 것
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
