주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7537 Wireless Card Replacement
필요한 것
  1. Dell Inspiron 15-7537 Wireless Card Replacement, Bottom Case: 1 단계, 이미지 1개 중 1개
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Wireless Card Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Wireless Card Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: 4 단계, 이미지 2개 중 2개
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  5. Dell Inspiron 15-7537 Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the two antennas (one black and one white) from the wireless card.
  6. Dell Inspiron 15-7537 Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jean Whitmore
회원 가입일: 01/22/15
984 평판
안내서 7개를 작성함
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 회원
CPSU-MANESS-W15S18G2
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 3,866
