소개
Use this guide to replace your Dell Inspiron 15-7537 WiFi card if you have determined your WiFi connection issues are caused by a faulty WiFi card.
필요한 것
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Use a spudger to remove the base cover from the rest of bottom cover.
As it is not clearly visible in the picture: You should start to open the base cover at the screen side, to avoid breaking the plastic guides of the base cover. A flat dough scraper is a pretty good tool for that.
Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
You missed a step where you have to remove the battery to get to the wireless card.
다른 한 분이 해당 안내서를 완성하였습니다.
