주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7547 LCD Assembly Replacement
필요한 것
  1. Dell Inspiron 15-7547 LCD Assembly Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 LCD Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: 3 단계, 이미지 2개 중 2개
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  4. Dell Inspiron 15-7547 LCD Assembly Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15-7547 LCD Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  5. Dell Inspiron 15-7547 LCD Assembly Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 15-7547 LCD Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
  6. Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: 6 단계, 이미지 3개 중 1개 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: 6 단계, 이미지 3개 중 2개 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: 6 단계, 이미지 3개 중 3개
    • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
  7. Dell Inspiron 15-7547 LCD Assembly Replacement: 7 단계, 이미지 3개 중 1개 Dell Inspiron 15-7547 LCD Assembly Replacement: 7 단계, 이미지 3개 중 2개 Dell Inspiron 15-7547 LCD Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Use a spudger to unlatch and unplug the display cable.
    • There will be a notch on the side of the connector.
  8. Dell Inspiron 15-7547 LCD Assembly Replacement: 8 단계, 이미지 3개 중 1개 Dell Inspiron 15-7547 LCD Assembly Replacement: 8 단계, 이미지 3개 중 2개 Dell Inspiron 15-7547 LCD Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Raise the left and right hinges.
  9. Dell Inspiron 15-7547 LCD Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the LCD display assembly from the laptop.
결론
작성자
2다른 기여자 명과 함께
Kevin Smith
회원 가입일: 09/10/18
321 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 889
