주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7547 WiFi Card Replacement
필요한 것
  1. Dell Inspiron 15-7547 WiFi Card Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 WiFi Card Replacement: 2 단계, 이미지 1/1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 WiFi Card Replacement, WiFi Card: 3 단계, 이미지 1/2 Dell Inspiron 15-7547 WiFi Card Replacement, WiFi Card: 3 단계, 이미지 2/2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  4. Dell Inspiron 15-7547 WiFi Card Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-7547 WiFi Card Replacement: 4 단계, 이미지 2/2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  5. Dell Inspiron 15-7547 WiFi Card Replacement: 5 단계, 이미지 1/2 Dell Inspiron 15-7547 WiFi Card Replacement: 5 단계, 이미지 2/2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
결론
Claro
회원 가입일: 09/10/18
591 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 322
