주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7548 Motherboard Replacement
필요한 것
  1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Motherboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-7548 Motherboard Replacement: 2 단계, 이미지 2/2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove the screws holding the battery.
  4. Dell Inspiron 15-7548 Motherboard Replacement: 4 단계, 이미지 1/1
    • Disconnect the battery ribbon connector.
  5. Dell Inspiron 15-7548 Motherboard Replacement: 5 단계, 이미지 1/1
    • Disconnect the CPU fan ribbon.
  6. Dell Inspiron 15-7548 Motherboard Replacement: 6 단계, 이미지 1/1
    • Disconnect the display screen ribbon connector.
  7. Dell Inspiron 15-7548 Motherboard Replacement: 7 단계, 이미지 1/1
    • Disconnect the blue ribbon connector.
  8. Dell Inspiron 15-7548 Motherboard Replacement: 8 단계, 이미지 1/1
    • Disconnect the blue and gold ribbon connectors.
  9. Dell Inspiron 15-7548 Motherboard Replacement: 9 단계, 이미지 1/1
    • Disconnect the speaker cable.
  10. Dell Inspiron 15-7548 Motherboard Replacement: 10 단계, 이미지 1/1
    • Disconnect the WiFi card connections.
  11. Dell Inspiron 15-7548 Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the screws securing the heat sink.
  12. Dell Inspiron 15-7548 Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove the heat sink.
  13. Dell Inspiron 15-7548 Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove the motherboard screws.
  14. Dell Inspiron 15-7548 Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove the motherboard.
결론
Michael Nunez
회원 가입일: 04/12/22
325 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-3, Beck Spring 2022 IUPUI, Team 3-3, Beck Spring 2022 회원
IUPUI-BECK-S22S3G3
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 16
전체 시간: 557
