주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7548 RAM Replacement
필요한 것
  1. Dell Inspiron 15-7548 RAM Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Inspiron 15-7548 RAM Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 RAM Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-7548 RAM Replacement: 2 단계, 이미지 2/2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Pull the clips away from the side of the RAM stick.
  4. Dell Inspiron 15-7548 RAM Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-7548 RAM Replacement: 4 단계, 이미지 2/2
    • Lift the RAM up and away from the motherboard.
  5. Dell Inspiron 15-7548 RAM Replacement: 5 단계, 이미지 1/1
    • If there is a second RAM stick, pull the clips away from the side of the RAM stick.
  6. Dell Inspiron 15-7548 RAM Replacement: 6 단계, 이미지 1/2 Dell Inspiron 15-7548 RAM Replacement: 6 단계, 이미지 2/2
    • Lift the RAM stick up and away from the motherboard.
결론
Michael Nunez
회원 가입일: 04/12/22
325 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-3, Beck Spring 2022 IUPUI, Team 3-3, Beck Spring 2022 회원
IUPUI-BECK-S22S3G3
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 18
전체 시간: 372
