주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7548 Speaker Replacement
필요한 것
  1. Dell Inspiron 15-7548 Speaker Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Inspiron 15-7548 Speaker Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Speaker Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-7548 Speaker Replacement: 2 단계, 이미지 2/2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Speaker Replacement, Battery: 3 단계, 이미지 1/2 Dell Inspiron 15-7548 Speaker Replacement, Battery: 3 단계, 이미지 2/2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548 Speaker Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-7548 Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Dell Inspiron 15-7548 Speaker Replacement, Speaker: 5 단계, 이미지 1/1
    • Remove the ribbon cable by pulling it out.
  6. Dell Inspiron 15-7548 Speaker Replacement: 6 단계, 이미지 1/2 Dell Inspiron 15-7548 Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the compression caps by using the spudger.
  7. Dell Inspiron 15-7548 Speaker Replacement: 7 단계, 이미지 1/1
    • Untangle the wire from the plastic clips and remove the speakers from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
brianna cordoway
회원 가입일: 09/26/18
151 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 837
