주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7559 Back Panel Replacement
필요한 것
  1. Dell Inspiron 15-7559 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Back Panel Replacement: 2 단계, 이미지 1/3 Dell Inspiron 15-7559 Back Panel Replacement: 2 단계, 이미지 2/3 Dell Inspiron 15-7559 Back Panel Replacement: 2 단계, 이미지 3/3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Back Panel Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-7559 Back Panel Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-7559 Back Panel Replacement: 3 단계, 이미지 3/3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
결론
To reassemble your device, simply press the back panel on until all pins snap back into place and then screw the back panel back on.
다른 3명이 해당 안내서를 완성하였습니다.
Trenton Greevebiester
회원 가입일: 10/19/17
1,536 평판
안내서 6개 작성하였습니다
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 회원
UWT-LINER-F17S3G2
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 27
전체 시간: 3,257
