소개
This is a guide to replace the monitor on the Dell Inspiron 15-7559 laptop. Which may be necessary if your monitor fails to display images.
필요한 것
다른 4명이 해당 안내서를 완성하였습니다.
댓글 5개
How do you replace the antenna cables around the display?
There are also six Phillips head screws (size 00) around the screen that have to be removed before you can flip the LCD forward.
I encountered 4 phillips screws, and the bezel was slightly different. Did not impact ability to replace screen
This laptop came with 2 screen options. A 1080p non-touch screen, and a 4K touch screen.
The example in this guide is of the 4K touchscreen. The 1080p screen is the display that has the 4 screws and large bezel.
Is it possible to replace a broken 4K screen with a full HD one?
