주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7559 Display Replacement
필요한 것
  1. Dell Inspiron 15-7559 Display Replacement, Display: 1 단계, 이미지 1/3 Dell Inspiron 15-7559 Display Replacement, Display: 1 단계, 이미지 2/3 Dell Inspiron 15-7559 Display Replacement, Display: 1 단계, 이미지 3/3
    • This next step will likely cause some of the tabs, that hold the display, to snap. They will still function and hold the display in place and there should be no noticeable issues once put back together, but the tabs will have permanent damage and repeated disassembly will most likely require replacement.
    • Using the metal or plastic spudger pry open the frame around the display.
  2. Dell Inspiron 15-7559 Display Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-7559 Display Replacement: 2 단계, 이미지 2/2
    • Pull the screen down and let it lie on the keyboard.
  3. Dell Inspiron 15-7559 Display Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-7559 Display Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-7559 Display Replacement: 3 단계, 이미지 3/3
    • Locate the wire that connects the display to the back panel. There will be a sticker with a qr code on it.
    • Peel the the sticker and pull it back to disconnect the cables.
  4. Dell Inspiron 15-7559 Display Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-7559 Display Replacement: 4 단계, 이미지 2/2
    • The display is now fully disconnected, you can now completely remove it from the computer.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Mason Ottinger
회원 가입일: 10/18/17
227 평판
안내서 1개 작성함
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 회원
UWT-LINER-F17S3G2
5 회원들
안내서 9개 작성하였습니다
댓글 5개
How do you replace the antenna cables around the display?
Prasanna Pokharel - 답글
There are also six Phillips head screws (size 00) around the screen that have to be removed before you can flip the LCD forward.
Ken Schoenberg - 답글
I encountered 4 phillips screws, and the bezel was slightly different. Did not impact ability to replace screen
Teddy Vandenberg - 답글
This laptop came with 2 screen options. A 1080p non-touch screen, and a 4K touch screen.
The example in this guide is of the 4K touchscreen. The 1080p screen is the display that has the 4 screws and large bezel.
Matthew Parker - 답글
Is it possible to replace a broken 4K screen with a full HD one?
george neverland - 답글
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 25
30일 전: 103
전체 시간: 14,259
