소개
This guide will demonstrate how to replace the hard drive for the Dell Inspiron 15-7559. This may be necessary if your laptop frequently crashes or if you're having issues booting it.
필요한 것
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Is there a step related to removing the hard drive mount? I believe that you’ll need the mount in order to screw a new drive into the system.
Are there other options beside the same seagate hard drive? I’m reading on forums that this hard drive is not very reliable. And since mine just completely died after less than 4 years I’m skeptable replacing it with the same exact hard drive?
Tee Rivera - 답글
