소개
This guide will demonstrate how to replace the keyboard for the Dell Inspiron 15-7559. This may be necessary if you are unable to use the keyboard.
필요한 것
Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 2개
How to put it back
Using Name - 답글
Do the steps in reverse order, like it says at the end of the tutorial
