주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7559 Keyboard Replacement
필요한 것
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-7559 Keyboard Replacement: 2 단계, 이미지 2/2
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-7559 Keyboard Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-7559 Keyboard Replacement: 3 단계, 이미지 3/3
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: 4 단계, 이미지 1/1
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Trenton Greevebiester
회원 가입일: 10/19/17
1,536 평판
안내서 6개 작성하였습니다
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 회원
UWT-LINER-F17S3G2
5 회원들
안내서 9개 작성하였습니다
댓글 2개
How to put it back
Using Name - 답글
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 44
전체 시간: 6,863
