소개
In this guide, we will be showing you how to remove and replace the Memory Modules.
필요한 것
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
다른 2명이 해당 안내서를 완성하였습니다.
