주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7567 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15-7567 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Hard Drive Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-7567 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Hard Drive Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-7567 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Hard Drive Replacement: 5 단계, 이미지 1/2 Dell Inspiron 15-7567 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/2 Dell Inspiron 15-7567 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2/2
    • Remove the four 5mm screws with a Phillips #1 screwdriver.
  8. Dell Inspiron 15-7567 Hard Drive Replacement: 8 단계, 이미지 1/3 Dell Inspiron 15-7567 Hard Drive Replacement: 8 단계, 이미지 2/3 Dell Inspiron 15-7567 Hard Drive Replacement: 8 단계, 이미지 3/3
    • Remove the cable from the motherboard that is attached to the Hard Drive.
    • Use your fingers or the plastic opening tools to gently pull up on the clip, freeing the cable.
  9. Dell Inspiron 15-7567 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Lift and remove Hard Drive.
결론
Dallas Lamorie
회원 가입일: 09/30/18
523 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,226
