주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7567 RAM Replacement
필요한 것
  1. Dell Inspiron 15-7567 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 RAM Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-7567 RAM Replacement: 2 단계, 이미지 2/2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 RAM Replacement: 3 단계, 이미지 1/1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 RAM Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-7567 RAM Replacement: 4 단계, 이미지 2/2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 RAM Replacement: 5 단계, 이미지 1/2 Dell Inspiron 15-7567 RAM Replacement: 5 단계, 이미지 2/2
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 RAM Replacement: 6 단계, 이미지 1/1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 RAM Replacement, RAM: 7 단계, 이미지 1/2 Dell Inspiron 15-7567 RAM Replacement, RAM: 7 단계, 이미지 2/2
    • Remove the 3mm screw on the back using a Phillips #1 screwdriver.
  8. Dell Inspiron 15-7567 RAM Replacement: 8 단계, 이미지 1/2 Dell Inspiron 15-7567 RAM Replacement: 8 단계, 이미지 2/2
    • Remove the panel by lifting up the side towards you
  9. Dell Inspiron 15-7567 RAM Replacement: 9 단계, 이미지 1/2 Dell Inspiron 15-7567 RAM Replacement: 9 단계, 이미지 2/2
    • Release the two clips on the left and right side, by pushing outward on the side towards you.
    • The RAM strip will extend out. Pull towards you at a slight angle.
결론
James Bedortha
회원 가입일: 09/28/18
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 685
