이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
Remove the panel from the sides and pull it out at an angle towards you.
Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
이 단계에 사용된 도구:Tweezers$4.99-
Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
Pinch the clips on the left and right side while pulling on the cord at the same time.
Remove the clip holding the power cord on the Touch Pad by using tweezers, your fingers, or iFixit removing tools to gently pull up on the clip.
This should release the power cord as shown.
Remove the four 3mm screws using a Phillips #1 screwdriver in the locations shown.
Remove Touch Pad by pulling towards you gently at a slight upward angle.
다른 2명이 해당 안내서를 완성하였습니다.
