주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 15-7567 Wireless Card Replacement
필요한 것
  1. Dell Inspiron 15-7567 Wireless Card  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Wireless Card  Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 15-7567 Wireless Card  Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Wireless Card  Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Wireless Card  Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15-7567 Wireless Card  Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Wireless Card  Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 15-7567 Wireless Card  Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Wireless Card  Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: 7 단계, 이미지 2개 중 1개 Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: 7 단계, 이미지 2개 중 2개
    • Remove the 3mm screw using the Phillips #0 screwdriver in the location shown.
    • Remove the grey panel as well.
  8. Dell Inspiron 15-7567 Wireless Card  Replacement: 8 단계, 이미지 1개 중 1개
    • Detach the black and white wires connected to the card by gently lifting up on the wires.
  9. Dell Inspiron 15-7567 Wireless Card  Replacement: 9 단계, 이미지 2개 중 1개 Dell Inspiron 15-7567 Wireless Card  Replacement: 9 단계, 이미지 2개 중 2개
    • Gently pull the wireless card out at an angle towards you.
결론
작성자
4다른 기여자 명과 함께
Rachel Holland
회원 가입일: 09/27/18
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 30
전체 시간: 1,033
