주요 콘텐츠로 건너뛰기
Dell Inspiron 1501 Keyboard Replacement
필요한 것
  1. Dell Inspiron 1501 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 1501 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 1501 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: 2 단계, 이미지 1/2 Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: 2 단계, 이미지 2/2
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Dell Inspiron 1501 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/3 Dell Inspiron 1501 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/3 Dell Inspiron 1501 Keyboard Replacement, Keyboard: 3 단계, 이미지 3/3
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Dell Inspiron 1501 Keyboard Replacement: 4 단계, 이미지 1/2 Dell Inspiron 1501 Keyboard Replacement: 4 단계, 이미지 2/2
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Don Dao
회원 가입일: 03/01/18
361 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 UMass Dartmouth, Team S2-G4, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 667
