주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 1501 Wireless Mini-Card Replacement
필요한 것
  1. Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Wireless Mini-Card Replacement, Hinge Cover: 2 단계, 이미지 2개 중 1개 Dell Inspiron 1501 Wireless Mini-Card Replacement, Hinge Cover: 2 단계, 이미지 2개 중 2개
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Dell Inspiron 1501 Wireless Mini-Card Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 1501 Wireless Mini-Card Replacement: 4 단계, 이미지 2개 중 2개
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 1501 Wireless Mini-Card Replacement, Wireless Mini-Card: 5 단계, 이미지 2개 중 1개 Dell Inspiron 1501 Wireless Mini-Card Replacement, Wireless Mini-Card: 5 단계, 이미지 2개 중 2개
    • Remove the two wires from their connections.
    • Pull the metal tabs securing the wireless mini-card to the back of the laptop until the card pops up.
    • Remove the wireless mini-card from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Don Dao
회원 가입일: 03/01/18
418 평판
안내서 4개를 작성함
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 UMass Dartmouth, Team S2-G4, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G4
4 회원들
안내서 7개를 작성함
2가이드 댓글
I have a computer like this. I have a problem that I have not been able to find a solution too. A few parts that support the screen are broken, and I need to know if I will not be able to replace the CPU in the future should I ever decide to cement these specific parts together.
Let me know if you need any more information!
Peter C.
Peter Chapin - 답글 공유
Trepću 3 zelene diode, kod prekidača za uključivanje i isključivanje, kad treba da startuje i da se uključi ekran i ostalo!
Šta to znači?
Rocky - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 48
전체 시간: 1,067
