주요 콘텐츠로 건너뛰기
Dell Inspiron 1521 Keyboard Replacement
필요한 것
  1. Dell Inspiron 1521 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Keyboard Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 1521 Keyboard Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 1521 Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Inspiron 1521 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Inspiron 1521 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Find the two small indentations of the sides of the panel covering the power button.
    • Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
  4. Dell Inspiron 1521 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Now that the panel is loose simply pull the panel off with your hand.
  5. Dell Inspiron 1521 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Dell Inspiron 1521 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Dell Inspiron 1521 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel.
    • Remove these screws with a Phillips #1 screwdriver.
    • With the screws removed pull the keyboard up with your hand.
  6. Dell Inspiron 1521 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 1521 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 1521 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the connector that links the keyboard to the laptop.
    • Gently pull the connector toward the screen of the laptop with your figers to disconnect it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nikolaus Powell
회원 가입일: 09/20/12
426 평판
안내서 3개를 작성함
Cal Poly, Team 15-47, Forte Fall 2012 Cal Poly, Team 15-47, Forte Fall 2012 회원
CPSU-FORTE-F12S15G47
5 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 8
전체 시간: 2,186
