소개
In this guide we will be showing you how to replace the battery on your Dell Inspiron 1525. You don't need any tools for this process.
Flip the computer upside down and locate the battery release switch.
  • Flip the computer upside down and locate the battery release switch.
  • Remember to disconnect any and all power sources when working on any electronic device to prevent damage.
댓글 쓰기
Slide and hold the switch away from the lock symbol to release the battery lock.
  • Slide and hold the switch away from the lock symbol to release the battery lock.
댓글 쓰기
Grip the battery and gently pull it away from the rest of the device. You can now let go of the battery release switch and let it return to its original position.
  • Grip the battery and gently pull it away from the rest of the device. You can now let go of the battery release switch and let it return to its original position.
댓글 쓰기
결론
다른 3명이 해당 안내서를 완성하였습니다.
Phil Hopkins
회원 가입일: 2010년 04월 18일
308 평판
안내서 1개 작성함
Cal Poly, Team 23-101, Johann Spring 2010 Cal Poly, Team 23-101, Johann Spring 2010 회원
CPSU-JOHANN-S10S23G101
2 회원들
안내서 1개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 17
전체 시간: 4,452
