주요 콘텐츠로 건너뛰기
Dell Inspiron 1525 Central Control Cover Replacement
필요한 것
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 1525 Central Control Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: 3 단계, 이미지 1개 중 1개
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 1525 Central Control Cover Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 1525 Central Control Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: 5 단계, 이미지 3개 중 1개 Dell Inspiron 1525 Central Control Cover Replacement: 5 단계, 이미지 3개 중 2개 Dell Inspiron 1525 Central Control Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Miroslav Djuric
159,496 평판
안내서 144개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 21
전체 시간: 3,647
