주요 콘텐츠로 건너뛰기
Dell Inspiron 1525 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 1525 Display Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Display Assembly Replacement: 2 단계, 이미지 1/2 Dell Inspiron 1525 Display Assembly Replacement: 2 단계, 이미지 2/2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Display Assembly Replacement, Central Control Cover: 3 단계, 이미지 1/1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Display Assembly Replacement: 4 단계, 이미지 1/3 Dell Inspiron 1525 Display Assembly Replacement: 4 단계, 이미지 2/3 Dell Inspiron 1525 Display Assembly Replacement: 4 단계, 이미지 3/3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Display Assembly Replacement: 5 단계, 이미지 1/3 Dell Inspiron 1525 Display Assembly Replacement: 5 단계, 이미지 2/3 Dell Inspiron 1525 Display Assembly Replacement: 5 단계, 이미지 3/3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
  6. Dell Inspiron 1525 Display Assembly Replacement, Keyboard: 6 단계, 이미지 1/2 Dell Inspiron 1525 Display Assembly Replacement, Keyboard: 6 단계, 이미지 2/2
    • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
    • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
  7. Dell Inspiron 1525 Display Assembly Replacement: 7 단계, 이미지 1/2 Dell Inspiron 1525 Display Assembly Replacement: 7 단계, 이미지 2/2
    • Use a spudger to gently lift the ribbon cable retaining flap.
    • Disconnect the ribbon cable.
    • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
    the flap broke? the little black piece. Now what do i do? I'm stuck at this step
    daaaammon - 답글
  8. Dell Inspiron 1525 Display Assembly Replacement, Bottom Cover: 8 단계, 이미지 1/2 Dell Inspiron 1525 Display Assembly Replacement, Bottom Cover: 8 단계, 이미지 2/2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  9. Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: 9 단계, 이미지 1/3 Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: 9 단계, 이미지 2/3 Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: 9 단계, 이미지 3/3
    • Disconnect the five antennas from their respective cards.
    • De-route the antennas from their routing retainers.
  10. Dell Inspiron 1525 Display Assembly Replacement: 10 단계, 이미지 1/1
    • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
  11. Dell Inspiron 1525 Display Assembly Replacement: 11 단계, 이미지 1/3 Dell Inspiron 1525 Display Assembly Replacement: 11 단계, 이미지 2/3 Dell Inspiron 1525 Display Assembly Replacement: 11 단계, 이미지 3/3
    • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
    • Carefully release the connector from its retaining tabs.
  12. Dell Inspiron 1525 Display Assembly Replacement: 12 단계, 이미지 1/2 Dell Inspiron 1525 Display Assembly Replacement: 12 단계, 이미지 2/2
    • Push the antenna wires up through their hole in the bottom case half.
    • Release the antennas from their retaining tabs on the upper case.
  13. Dell Inspiron 1525 Display Assembly Replacement: 13 단계, 이미지 1/2 Dell Inspiron 1525 Display Assembly Replacement: 13 단계, 이미지 2/2
    • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
    • Free the ribbon cable from its retaining clips.
  14. Dell Inspiron 1525 Display Assembly Replacement: 14 단계, 이미지 1/1
    • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
    • Remove the display assembly from the laptop.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Miroslav Djuric
158,300 평판
안내서 144개 작성하였습니다
댓글 한 개
Hi There,
Thanks for the great article. Can you please advise what is the part number (LCD number). For example I have LTN156AT17-101 for my Inspiron N5110. I am actually planning to use the screen from 1525 to replace the one in N5110. Are they both same connector type? Thanks.
Zaheer Meerja - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 14
전체 시간: 9,636
