이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the battery release switch away from the lock symbol until you hear the battery click.
Slide the battery towards the back of the laptop until it comes free.
Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
Carefully pull the central control cover up along its edges.
Peel back the silver tape securing the ribbon cable to the cover.
Pull the small brown latch on the ribbon cable connector out.
Disconnect the ribbon cable to completely free the central control cover.
Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
Gently slide the keyboard towards the display until the tabs on its front side are free.
Use a spudger to gently lift the ribbon cable retaining flap.
Disconnect the ribbon cable.
Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Disconnect the five antennas from their respective cards.
De-route the antennas from their routing retainers.
Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
Carefully release the connector from its retaining tabs.
Push the antenna wires up through their hole in the bottom case half.
Release the antennas from their retaining tabs on the upper case.
Disconnect the flat LCD ribbon cable by pulling it up by the tab.
Free the ribbon cable from its retaining clips.
Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
Remove the display assembly from the laptop.
Use the pointed side of a spudger to peel the six small rubber feet off the display assembly.
Remove the six 6.05 mm Phillips #1 screws hidden beneath each of the rubber feet.
Use the flat end of a spudger to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
Remove the front display bezel when it comes free.
Remove the two 5.70 mm Phillips #1 screws securing the LCD to the display assembly.
Remove the LCD from the display assembly.
다른 15명이 해당 안내서를 완성하였습니다.
