소개
Use this guide to help you replace the RAM in a Dell Inspiron 1525.
필요한 것
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
거의 끝나갑니다!
결론
다른 5명이 해당 안내서를 완성하였습니다.
