주요 콘텐츠로 건너뛰기
Dell Inspiron 1526 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 1526 Hard Drive Replacement, Remove the Screws: 1 단계, 이미지 1/1
    • Follow the procedures in Before You Begin.
    • Turn the computer over and remove the two hard drive screws.
  2. Dell Inspiron 1526 Hard Drive Replacement, Sliding the Hard Drive: 2 단계, 이미지 1/1
    • Slide the hard drive out of the computer.
  3. Dell Inspiron 1526 Hard Drive Replacement, Remove the Screws: 3 단계, 이미지 1/2 Dell Inspiron 1526 Hard Drive Replacement, Remove the Screws: 3 단계, 이미지 2/2
    • Remove the two screws (one from each side of the hard drive cover), then pull to separate the cover from the hard drive.
  4. Dell Inspiron 1526 Hard Drive Replacement, Replace the Hard Drive Cover: 4 단계, 이미지 1/2 Dell Inspiron 1526 Hard Drive Replacement, Replace the Hard Drive Cover: 4 단계, 이미지 2/2
    • Replace the hard drive cover and tighten the two screws to secure the cover to the NEW hard drive.
  5. Dell Inspiron 1526 Hard Drive Replacement, Sliding the Hard Drive: 5 단계, 이미지 1/1
    • NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector.
    • Slide the hard drive into the hard drive bay until the drive is fully seated.
  6. Dell Inspiron 1526 Hard Drive Replacement, Replace the Screws: 6 단계, 이미지 1/1
    • Replace the two screws to secure the hard drive.
결승점
Terrence15
회원 가입일: 12/18/17
79,121 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 166
