주요 콘텐츠로 건너뛰기
Dell Inspiron 1526 Heat Sink Replacement
필요한 것
  1. Dell Inspiron 1526 Heat Sink Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 1526 Heat Sink Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 1526 Heat Sink Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: 2 단계, 이미지 1/2 Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the eight 3mm screws from the rear casing of the laptop.
  3. Dell Inspiron 1526 Heat Sink Replacement: 3 단계, 이미지 1/2 Dell Inspiron 1526 Heat Sink Replacement: 3 단계, 이미지 2/2
    • Loosen the five captive Phillips #0 screws from the heat sink.
    • Lift the heat sink from the motherboard.
  4. Dell Inspiron 1526 Heat Sink Replacement: 4 단계, 이미지 1/2 Dell Inspiron 1526 Heat Sink Replacement: 4 단계, 이미지 2/2
    • Apply a pea-sized amount of new thermal paste to the CPU and GPU.
결론
Caleb Mink
회원 가입일: 09/17/19
147 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 156
