주요 콘텐츠로 건너뛰기
Dell Inspiron 1526 Screen Replacement
필요한 것
  1. Dell Inspiron 1526 Screen Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 1526 Screen Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 1526 Screen Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Screen Replacement, Keyboard: 2 단계, 이미지 1/1
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Screen Replacement: 3 단계, 이미지 1/1
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Screen Replacement: 4 단계, 이미지 1/1
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Screen Replacement: 5 단계, 이미지 1/1
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Screen Replacement: 6 단계, 이미지 1/2 Dell Inspiron 1526 Screen Replacement: 6 단계, 이미지 2/2
    • Remove the control cover.
  7. Dell Inspiron 1526 Screen Replacement: 7 단계, 이미지 1/1
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Screen Replacement: 8 단계, 이미지 1/1
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Screen Replacement: 9 단계, 이미지 1/2 Dell Inspiron 1526 Screen Replacement: 9 단계, 이미지 2/2
    • Remove the keyboard.
  10. Dell Inspiron 1526 Screen Replacement, Screen: 10 단계, 이미지 1/2 Dell Inspiron 1526 Screen Replacement, Screen: 10 단계, 이미지 2/2
    • Remove the six plastic pads around the bezel using an iFixit opening pick.
    • Remove the six 3mm Phillips #0 screws under each pad.
  11. Dell Inspiron 1526 Screen Replacement: 11 단계, 이미지 1/3 Dell Inspiron 1526 Screen Replacement: 11 단계, 이미지 2/3 Dell Inspiron 1526 Screen Replacement: 11 단계, 이미지 3/3
    • Open the computer so that it rests flat on the table.
    • Separate the bezel from the black plastic frame using a spudger.
    • There are a dozen snaps around the perimeter of the bezel and there are two between the pivot joints of the laptop.
  12. Dell Inspiron 1526 Screen Replacement: 12 단계, 이미지 1/2 Dell Inspiron 1526 Screen Replacement: 12 단계, 이미지 2/2
    • Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
    • Lift the display slightly from the top, then pull outwards.
    • Flip the display panel around to the back.
    • Disconnect the connector and remove the ribbon cable.
결론
Ahmed Alshamsi
회원 가입일: 09/17/19
181 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 163
