주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 1526 Webcam Replacement
필요한 것
  1. Dell Inspiron 1526 Webcam Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron 1526 Webcam Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron 1526 Webcam Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Webcam Replacement, Keyboard: 2 단계, 이미지 1개 중 1개
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Webcam Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Webcam Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Webcam Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Webcam Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron 1526 Webcam Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the control cover.
  7. Dell Inspiron 1526 Webcam Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Webcam Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Webcam Replacement: 9 단계, 이미지 2개 중 1개 Dell Inspiron 1526 Webcam Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the keyboard.
  10. Dell Inspiron 1526 Webcam Replacement, Screen: 10 단계, 이미지 2개 중 1개 Dell Inspiron 1526 Webcam Replacement, Screen: 10 단계, 이미지 2개 중 2개
    • Remove the six plastic pads around the bezel using an iFixit opening pick.
    • Remove the six 3mm Phillips #0 screws under each pad.
  11. Dell Inspiron 1526 Webcam Replacement: 11 단계, 이미지 3개 중 1개 Dell Inspiron 1526 Webcam Replacement: 11 단계, 이미지 3개 중 2개 Dell Inspiron 1526 Webcam Replacement: 11 단계, 이미지 3개 중 3개
    • Open the computer so that it rests flat on the table.
    • Separate the bezel from the black plastic frame using a spudger.
    • There are a dozen snaps around the perimeter of the bezel and there are two between the pivot joints of the laptop.
  12. Dell Inspiron 1526 Webcam Replacement: 12 단계, 이미지 2개 중 1개 Dell Inspiron 1526 Webcam Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
    • Lift the display slightly from the top, then pull outwards.
    • Flip the display panel around to the back.
    • Disconnect the connector and remove the ribbon cable.
  13. Dell Inspiron 1526 Webcam Replacement, Webcam: 13 단계, 이미지 2개 중 1개 Dell Inspiron 1526 Webcam Replacement, Webcam: 13 단계, 이미지 2개 중 2개
    • Detach the webcam connector.
  14. Dell Inspiron 1526 Webcam Replacement: 14 단계, 이미지 1개 중 1개
    • From both sides, pry and pull upwards from the back of the display cover.
    • This module has no screws affixing it to the display cover; it is held in by snapping it into the plastic brackets.
결론
작성자
4다른 기여자 명과 함께
Ahmed Alshamsi
회원 가입일: 09/17/19
181 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 50
전체 시간: 438
