이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the unlock button to the left to release the battery.
Slide the battery away from the laptop to remove.
Flip the laptop over.
Lift the control cover by prying the right side of the cover with an iFixit opening tool.
Carefully lift the control cover up and forward to reveal a single ribbon cable.
Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
Lift the keyboard gently from the top, but do not remove completely.
Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
Remove the six plastic pads around the bezel using an iFixit opening pick.
Remove the six 3mm Phillips #0 screws under each pad.
Open the computer so that it rests flat on the table.
Separate the bezel from the black plastic frame using a spudger.
Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
Lift the display slightly from the top, then pull outwards.
Flip the display panel around to the back.
Disconnect the connector and remove the ribbon cable.
From both sides, pry and pull upwards from the back of the display cover.
