주요 콘텐츠로 건너뛰기
Dell Inspiron 1545 CPU Heat Sink Replacement
필요한 것
  1. Dell Inspiron 1545 CPU Heat Sink Replacement, Battery: 1 단계, 이미지 1/1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 CPU Heat Sink Replacement: 2 단계, 이미지 1/1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 CPU Heat Sink Replacement: 3 단계, 이미지 1/1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 CPU Heat Sink Replacement, Base Cover: 4 단계, 이미지 1/1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 CPU Heat Sink Replacement: 5 단계, 이미지 1/2 Dell Inspiron 1545 CPU Heat Sink Replacement: 5 단계, 이미지 2/2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 CPU Heat Sink Replacement, CPU Heat Sink: 6 단계, 이미지 1/1
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 CPU Heat Sink Replacement: 7 단계, 이미지 1/1
    • Pull up on the Heat Sink unit to remove it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Nathan Lemay
회원 가입일: 04/16/14
3,064 평판
안내서 15개 작성하였습니다
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 회원
CPSU-REGAN-S14S9G14
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 23
전체 시간: 2,067
