주요 콘텐츠로 건너뛰기
Dell Inspiron 1545 Center Control Cover Replacement
필요한 것
  1. Dell Inspiron 1545 Center Control Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Center Control Cover Replacement: 2 단계, 이미지 1/1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Center Control Cover Replacement: 3 단계, 이미지 1/1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Center Control Cover Replacement, Center Control Cover: 4 단계, 이미지 1/1
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  5. Dell Inspiron 1545 Center Control Cover Replacement: 5 단계, 이미지 1/1
    • Flip the laptop over to the front and open the display as far as possible.
  6. Dell Inspiron 1545 Center Control Cover Replacement: 6 단계, 이미지 1/3 Dell Inspiron 1545 Center Control Cover Replacement: 6 단계, 이미지 2/3 Dell Inspiron 1545 Center Control Cover Replacement: 6 단계, 이미지 3/3
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nathan Lemay
회원 가입일: 04/16/14
3,064 평판
안내서 15개 작성하였습니다
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 회원
CPSU-REGAN-S14S9G14
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 22
전체 시간: 2,729
