주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 1545 Computer Processing Unit Replacement
필요한 것
  1. Dell Inspiron 1545 Computer Processing Unit Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Computer Processing Unit Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Computer Processing Unit Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Computer Processing Unit Replacement, Base Cover: 4 단계, 이미지 1개 중 1개
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 Computer Processing Unit Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 1545 Computer Processing Unit Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Computer Processing Unit Replacement, CPU Heat Sink: 6 단계, 이미지 1개 중 1개
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 Computer Processing Unit Replacement: 7 단계, 이미지 1개 중 1개
    • Pull up on the Heat Sink unit to remove it.
  8. Dell Inspiron 1545 Computer Processing Unit Replacement, Computer Processing Unit: 8 단계, 이미지 1개 중 1개
    • Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
  9. Dell Inspiron 1545 Computer Processing Unit Replacement: 9 단계, 이미지 1개 중 1개
    • The CPU is very fragile and has thin pins.
    • Remove the CPU by pulling straight upward and away from the laptop.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nathan Lemay
회원 가입일: 04/16/14
3,145 평판
안내서 15개를 작성함
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 회원
CPSU-REGAN-S14S9G14
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 36
전체 시간: 3,054
