주요 콘텐츠로 건너뛰기
Dell Inspiron 1545 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 1545 Hard Drive Replacement, Remove the Screws: 1 단계, 이미지 1/1
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Remove the two screws securing the hard drive assembly to the computer base.
  2. Dell Inspiron 1545 Hard Drive Replacement, Sliding the Hard Drive Assembly: 2 단계, 이미지 1/1
    • Slide the hard drive assembly out of the bay.
  3. Dell Inspiron 1545 Hard Drive Replacement, Remove the Screws: 3 단계, 이미지 1/1
    • Remove the two screws (one from either side) securing the hard drive cage and bezel to the hard drive.
  4. Dell Inspiron 1545 Hard Drive Replacement, Remove the Hard Drive Bezel: 4 단계, 이미지 1/1
    • Remove the hard drive bezel.
  5. Dell Inspiron 1545 Hard Drive Replacement, Lifting the Hard Drive: 5 단계, 이미지 1/2 Dell Inspiron 1545 Hard Drive Replacement, Lifting the Hard Drive: 5 단계, 이미지 2/2
    • Lift the hard drive cage off the hard drive.
  6. Dell Inspiron 1545 Hard Drive Replacement, Replace the Hard Drive Cage: 6 단계, 이미지 1/2 Dell Inspiron 1545 Hard Drive Replacement, Replace the Hard Drive Cage: 6 단계, 이미지 2/2
    • Replace the hard drive cage and the hard drive bezel.
  7. Dell Inspiron 1545 Hard Drive Replacement, Replace the Screws: 7 단계, 이미지 1/1
    • Replace the two screws (one on either side) that secure the hard drive cage and bezel to the NEW hard drive.
  8. Dell Inspiron 1545 Hard Drive Replacement, Sliding the Hard Drive Assembly: 8 단계, 이미지 1/1
    • Slide the hard drive assembly into the bay.
  9. Dell Inspiron 1545 Hard Drive Replacement, Replace the Screws: 9 단계, 이미지 1/1
    • Replace the two screws that secure the hard drive assembly to the computer base.
    • NOTICE: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage to the computer.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,243 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 47
전체 시간: 5,503
