소개
There are multiple issues that can arise with the keyboard, this guide will allow you to fix a number of them. Using this guide you can clean the keyboard or access some of the more complex components of the laptop.
After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 2개
Step 4 and 5 are not needed.
