소개
This guide will be utilized if you are having issues with reading disks and it is not a firmware problem.
필요한 것
Flip the laptop to its back side.
Remove the screw (5mm Phillips #1) that secures the Optical Disk Drive on the back of the laptop.
You really don’t need to have the “Flip the laptop to its back side” comment here, as you should have already done that to get the battery out due to having to slide the battery latch, which is on the bottom.
다른 3명이 해당 안내서를 완성하였습니다.
