주요 콘텐츠로 건너뛰기
Dell Inspiron 1545 Power Button Board Replacement
필요한 것
  1. Dell Inspiron 1545 Power Button Board Replacement, Power Button Board: 1 단계, 이미지 1/1
    • Turn the laptop off and disconnect it from all power sources.
    • Turn the laptop over so that the bottom is facing upwards.
  2. Dell Inspiron 1545 Power Button Board Replacement: 2 단계, 이미지 1/1
    • Slide the release latch while simultaneously pulling the battery outwards.
  3. Dell Inspiron 1545 Power Button Board Replacement: 3 단계, 이미지 1/1
    • Slide the battery completely out of the bay.
  4. Dell Inspiron 1545 Power Button Board Replacement: 4 단계, 이미지 1/1
    • Once the battery has been removed, take out the two screws (3mm Phillips #1) beneath it. These screws hold the center control cover in place.
  5. Dell Inspiron 1545 Power Button Board Replacement: 5 단계, 이미지 1/1
    • Flip the laptop back over to the front and push the screen open as far as possible.
  6. Dell Inspiron 1545 Power Button Board Replacement: 6 단계, 이미지 1/3 Dell Inspiron 1545 Power Button Board Replacement: 6 단계, 이미지 2/3 Dell Inspiron 1545 Power Button Board Replacement: 6 단계, 이미지 3/3
    • The center control cover is very fragile; be careful when prying it off.
    • Pry the center control cover off of the laptop using a plastic opening tool. On the right side of the cover, there is a small divot to help you start removing the cover.
    • Carefully lift the central control cover away from the laptop.
  7. Dell Inspiron 1545 Power Button Board Replacement: 7 단계, 이미지 1/1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  8. Dell Inspiron 1545 Power Button Board Replacement: 8 단계, 이미지 1/1
    • Be careful when pulling the keyboard away from the laptop, you may damage the connector holding it to the motherboard.
    • Using your hands, push the keyboard out and away from the laptop.
  9. Dell Inspiron 1545 Power Button Board Replacement: 9 단계, 이미지 1/2 Dell Inspiron 1545 Power Button Board Replacement: 9 단계, 이미지 2/2
    • Lift the connector latch to remove the keyboard cable from the motherboard.
    • Lift the keyboard away from the laptop.
  10. Dell Inspiron 1545 Power Button Board Replacement: 10 단계, 이미지 1/1
    • Lift the connector latch to remove the power button board from the motherboard.
    • Pull on the blue plastic tab to help prevent causing any damage to the connector.
  11. Dell Inspiron 1545 Power Button Board Replacement: 11 단계, 이미지 1/1
    • Pry the power button board out with your finger.
    • Pull the power button board away from the laptop.
결론
Michael Hill
회원 가입일: 02/28/18
193 평판
안내서 1개 작성함
University of Memphis, Team S5-G9, Baddour Spring 2018 University of Memphis, Team S5-G9, Baddour Spring 2018 회원
UM-BADDOUR-S18S5G9
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 2,170
